roadster198
- Aug 25, 2020
- SL350 R230 2009
reccomend that ,i followed it ,it deffo works ,tho in my case i carried it out anyway,it was not leaking ,if as in my case you find no corrosion its real easy to do on a nice weekend, about a day if yr in no hurry. then lift yr pump into a ,in my case 5mm polystrene tile in a zip plastic freezer bag, if water ever did get in again ,the pump is safer.
Hi, Do you have any pictures of your fix? Can I do the plastic bag fix with the PSE as well?
