Sl320 R129 Wiper stuck on slow all the time
atlantimd
Ireland
mercedes benz E220 cdi estate W211 facelift 2008. Mercedes SL320 R129 1996.
Hi My 96 SL320 has wiper on slow when ever Ignition is in position 1 or 2 ,started. I have isolated it to the Combination relay P/n: 140 820 71 26. Wiper still operating with stalk switch disconnected. It stops when Combination replay is removed. When connecting combination relay it seems to get a GND from pin 7 on the larger connector with slide lock.
Has anyone came across this issue before. I need schematic and searched the web but cant get my 96 model.
Any help would be great
Sounds like the parking switch has failed making the wiper motor continue to run to try to park the wipers.
atlantimd
atlantimd
Ireland
Thanks lost Kiwi. Is the parking switch part of the wiper motor, I did open it to check was it clean and gasket was a bit wet.
atlantimd
atlantimd
Ireland
Can this be repaired or is it replacement motor. I was checking for dry solder joints in the combination relay with soldering Iron. Your idea makes more sense
atlantimd
atlantimd
Ireland
Thanks for the link, I will strip it down tomorrow to see can I find problem.
atlantimd
atlantimd
Ireland
I have cleaned motor tracks and The fault is now intermittent. Sometimes on 2 wires from combination relay have 12V this is purely intermittent also wiper stopped mid screen. Im thinking its the big Combination relay 140 820 71 26 at fault.
I'd still put money on the wiper motor.
atlantimd
atlantimd
Ireland
I Hope you are right LostKiwi, I will stick at it and let you know. The newer relay does not seem to be as troublesome as the older version
atlantimd
atlantimd
Ireland
Relay Repair fixed the issue. I was thinking It was the relay as it was Putting out voltage with wiper disconnected and that was Intermittent
