Uncle Benz
- Mar 31, 2006
- Age
- 53
- Location
- West Sussex
- Mainly Mercedes
About half an hour is all it takes.
Got an issue with the windscreen wiper not working and the orange warning roll bar symbol comes up when the stalk is pushed or turned.
Checked the voltage in the boot battery well over 12 volts, but strangely when I move the roll bar switch on the central console up or down the windscreen wipers work again.
Anybody had a similar issue like that?
Checking the battery in the boot which is a proper MB battery dated 2016, is there a chance they fitted the wrong variant causing this issue?
Hello, I realise the problem you had with your SL was quite some time ago, but did you get to the root of the problem? I’ve resourced numerous searches the ignition switch is often mentioned. Mine is stored in the garage auxiliary battery is on trickle charge. It all seems to clear after just a few miles. Any help would be immensely appreciated. ThanksGot an issue with the windscreen wiper not working and the orange warning roll bar symbol comes up when the stalk is pushed or turned.
