Sl500 LEFT FRONT ABC VALVE LEAKING UNDER THE HEADLIGHT
Loik
Sl 500 2003
Hey everybody I’m new here bought an sl500 03 last week and my front abc valve started leaking, the car been parked since then, even with all this leaks the car won’t sink, ive attached a picture and it’s leaking from top of the valve
Hi and welcome. Your picture doesn't seem to have loaded?
L
Loik
Sl 500 2003
ajlsl600
france
Not dropping because check valves are closed and Yr leak will not be on that line. But it must be fixed.
00slk
Cambridgeshire UK
Been there, done that :rolleyes:
ajlsl600
france
Same. Inside p/rear of front wing. Leaking pipe about 12 inch long. 100 quid from benz!! Only one tf.
L
Loik
Sl 500 2003
this is driver side front valve that’s leaking, so how should I open it
ajlsl600
france
Get a print out from wis and go from there, you will need to be real fussy about keeping all clean. Any crxp you leave in or introduce will go thru system before getting filtered. Unless ur leak is from rtn line.
Filtering on rtn is cheapskate design. Theory is it will stay clean enough to get thru warranty, only way to mitigate is far more frequent oil changes than design. As most abc are not daily runners I wud be doin mine one a Yr. As with muy oils and filters.
Remove the valve block then follow the rebuild guides on YouTube. There are plenty to choose from.
Scrupulous cleanliness is required.
Frankly I'm surprised it's the valve block as there aren't many places it can leak.
ajlsl600
france
90%seal and or o, ring. Or leaking from a screwed in sensor/switch. Even with benz cost cutting. V slim chance of crack in housing.
L
Loik
Sl 500 2003
L
Loik
Sl 500 2003
So it’s coming from that but right there, the one that no hoses connected
L
Loik
Sl 500 2003
I mean the NUT **
L
Loik
Sl 500 2003
L
Loik
Sl 500 2003
Update so I got the nut out I’m gonna change the o ring and we will see
Change the sealing washer too. That will be where the leak is.
