Hey everybody I’m new here bought an sl500 03 last week and my front abc valve started leaking, the car been parked since then, even with all this leaks the car won’t sink, ive attached a picture and it’s leaking from top of the valve
Get a print out from wis and go from there, you will need to be real fussy about keeping all clean. Any crxp you leave in or introduce will go thru system before getting filtered. Unless ur leak is from rtn line.
Filtering on rtn is cheapskate design. Theory is it will stay clean enough to get thru warranty, only way to mitigate is far more frequent oil changes than design. As most abc are not daily runners I wud be doin mine one a Yr. As with muy oils and filters.
Mercedes-Benz Servicing, repairs, engine and diagnostics Wayne Gates - Mercedes-Benz, Unit F3, Phoenix Industrial Estate, Rosslyn Crescent, Harrow, Middlesex, HA1 2SP Tel: 020 8863 9233 Established for 20 years all vehicles washed and vacuumed.
