SL55 (R230) - ABC Visit Workshop
I think that the exhaust has to come off anyway.
I have never removed that bolt nor exhausts to swap a leg out, have you looked on WIS Malc???
star
Reading
Smart + others :)
I started the strut removal today however I'm a little stuck :confused:
I have removed the 18mm nut to Detach the spring control arm from the rear axle (6a in diagram) but I am not able to remove the bolt it doesn't budge.
Any ideas?
Have fun with that one, it seizes in the sleeve inside the bush. We have had to dismantled the other end to remove shock. A lot more work but still easier that cutting bolt out.
Thats what it says Cole at point 12. I think that C A R S E has wis as that picture is taken from it.
C A R S E
C A R S E
Edinburgh
R230, SL55 AMG
  • #105
Well finally got the strut fitted and........
All looks good, took the car a run and no errors :) hope that's it fixed.
Good one and pleased for you :D:D
Renntechsl500
R230 sl500 renntech
Hi sir
i have the same problem with my car
c1526-008 right rear valve stuck
you finally changed your rear right strut and you said you hope the problem is over.
Did your problem go away when you changed the strut ?
I am waiting for your answer, I suffered a lot to solve the problem.
I'll be happy if you can help me
Craiglxviii
Cambs UK
Hi sir
Resurrecting an olllld thread here…
What system are you using to get the error code? Is it generic or MB-specific?
Craiglxviii
Cambs UK
Mb-specific
Error code c1526-008 which is y36/2y3
In that case, you need to remove, strip, clean and replace your rear valve block. Luckily not a hard or expensive job. New o-rings should be c.40£
