D
DavidWMJones
Hello
Great Forum people. Hello to you all. This is my first post so hopefully it is in the right place.
I have an SLK230 2003. The ABS and ESP lights came on a while ago, but I just ignored it as drove ok and I didn't have the cash (£60) for MB check.
Now, a week later it's gone into limp home mode.
I've tried changing the brake pedal switch (as shown/indicated here). If I reset the errors by moving the steering wheel left then right it comes back on about a second or so after I start the engine.
When I start the car, at first I can change down the gears (automatic) but after a drive a litle bit (20 meters or so), it sticks in whichever gear indicated on the dash (1/2/3/4) and is in the limp home mode (1st gear).
I noticed that in my boot (trunk) was very wet, full of moisture. Lots of water in the spare wheel and the foam around he PSE unit is very wet.
I've taken it to an independent garage wgo has the Star system and got lots of error codes.
ESP
C1102-004, C1103-002, C1103-004, C1103-016, C1200, C1120-004, C1202, C1025-002, C1025-004
ETC
P2400, P2401
ESM
P1861, P1860
(plus more) but generally indicating fault with both rear speed sensors and yaw rate sensor, and ABS faulty.
The garage think it's an electrical problem, probably a lose connection somewhere.
I've removed the centre console, inspected YAW, acceleration and looked at the rear speed sensors. Nothing obvious other that lots of water in the rear sensor plug where it connects to the main shell of the car on both sides. I've dried this as best I could.
I still have the problem. If I take it to dealer to do another diagnostic check, would they be able to give me any more information, is it worth it?
I'd like to repair it myself for the sense of achievement and also because I took it another Mecedes Specialist garage 6 months ago when it had exactly the same problem. Not a good experience with them, as initial quote of £50 went to £600 without asking. Then they replaced speed sensors and the ABS Pump Control Unit which I supplied second hand. Still that's another story.
Any ideas? Should I take it to a dealer, could it be the ABS Pump/ESP controller again?
Thanks in advance for any help
ESP
ETC
P2400, P2401
ESM
P1861, P1860
