slk 230 running fault
lrsmech
can anyone help me i am new to site this slk 230 2000 model has a flat spot on eccelleration can anyone shed some light on how to repair it
rovingHawk
Tamworth
SLK230K, Mondeo Estate, Blackbird
Check the air filter, replace if necessary.
Clean the MAF.
Change the gearbox oil.
It's amazing how many faults can be sorted by just those 3 things.
RH
antijam
Gloucestershire
2003 SLK320
sorry what is the MAF
Mass Air Flow sensor.
The location of yours is shown (not very clearly I'm afraid) here. Click on 'Component location' and then on 'B2/5'.
General procedure for cleaning it is outlined in the DIY section of this forum here
You may get a reply from someone who has actually done it on your engine.
You could try just unplugging it and try the car,, pull the connector off the camshaft adjuster and see if it is oily at all,,it right at the top on the front middle of the engine
