SLK R170 rear demister
Kylinski
cardiff
SLK R170 230 (2001)
I have a few questions regarding the rear screen demister.
(I have posted about this problem previously, sorry)
If there is a 'break' in one or two of the elements (lines) in the screen (in my case the bottom two), would the remaining 'lines' still work?
I have checked the fuse, I have a light on at the switch and I have 'repaired' the breaks in the lines using the silver paint on substance.
Still not working :(
In my previous post, a second fuse in the boot was mentioned. Anyone know where that is?
Also, there was mention of a 'relay' at the rear of the car? Where would that be?
Thanks in advance :)
A
andy@pcd-ltd
Have you used a volt meter to check to see if there is voltage actually going to the rear screen
No he has not, I have told him 1357943 times:rolleyes: to check this, the connector X19 is in the side of the rear wing and this is the connector for the screen, on the 170449 no fuse no relay
Kylinski
Kylinski
cardiff
SLK R170 230 (2001)
Oh Malc you do exagerate somewhat. 1357942 times to be exact :shock:
Ok, 'assuming' there is juice to the rear screen, would the element lines without breaks in them still work?
I don't have a voltmeter :(
:D:D
It depends on how the screen it wired, you have the strands or wire in the glass going horizontally, if they go into a solid thicker wire at each side going vertical, that runs from top to bottom, then they are individual horizontal elements.
If the horizontal wires go along and drop down just into the next horizontal line then just on element and a break anywhere will stop it.
A volt meter that only cost £5 or less would do for checking, and I could send you the details of where this X connector is on your car.
Would you pop up the next 3 numbers after WDB170 and I can double check your system
Kylinski
Kylinski
cardiff
SLK R170 230 (2001)
Cheers :)
Next 3 digits are 449
Just had a look at the screen. Difficult to say how the element runs as the horizontal lines dissapear into the 'smoked' glass around the edge :(
OK then 449 was the one I gave the info for.
If you had a little multi meter,,you could check the voltage on that X connector and the resistance of the rear window, you would then know for sure :D
Kylinski
Kylinski
cardiff
SLK R170 230 (2001)
I've just gone back out to the car for another lookie from the inside of the screen.
There are 2 lines running vertical either side of the screen. On the drivers side I noticed a wire soldered have way up the screen. Couldn't see one on the passenger side, will check tomorrow in the daylight.
This is sort of good news as I think it means that despite the possible damage to the bottom 2 lines, the rest should still work??
Indeed this is the more normal way for them to be wired. The connections are normally both on the same side
