SLK32 engine no power: Advice please
sailorP
North Herefordshire
SLK32AMG
My SLK32AMG (2002 - 40k miles) has developed a problem.
It lacks power :-(
Normally, I can press the accelerator on the motorway at 70 plus (Kph of course), and get a big kick in the back as the car changes down and rapidly accelerates to 100 or so.
Yesterday on the way back from Heathrow I tried to accelerate above 80, but all that happened was the car changed down (to third I think), revs went to about 5k, but hardly any acceleration. I tried the gearbox in Sport ad Winter modes, basically same result...no power.
There were no warning lights, and no unusual noises, just the usual engine roar, but it was all sound and no fury....
Car had beeen standing in the cold for several days in the airport long term parking.
I pulled off the motorway, and tried some acceleration tests down the slip road and dual carriaeway to home. It accelerated at lower speeds, but not with the normal ferocity.
Hmmmm....sounds like I might have the intercooler water pump failure.
I understand from reading posts here that it normally happens around 60k miles, so looks like I'm unlucky.
I didn't want to pre-judge, so I thought I would test when cold.
Early this morning I went straight to the motorway (about a mile from home, so car was cold), and without any mechanical sympathy whatsoever, gave it some beans from the slip road onto the main carriageway. It accelerated better, but not with all of its customary venom.
I don't like mistreating the car, I normally warm it up properly before using full throttle, but I thought that doing a cold test just the once might help isolate the cause.
Further into the journey, when the engine was properly warm, I tried again, and same as last night, no power.
Did a one hour run in the car round the town with no problems, car behaved itself throughout, no symtoms.
Going home, same thing, no power at high speed.
So......
This sounds to me like the known problem of the intercooler water pump failing, (which presumably would also occur with C32AMGs as well?).
So can anyone shed some light on the following questions:
1. Am I doing the car any harm by driving it to my MD dealer or Indie?
2. Are there any other possible causes for this sort of failure? (I bet there are a few, but less probable).
3. Is there any (easy) test that I can perform to prove it is or isn't the water pump?
4. Since I have no warning lights, will there be fault codes for a STAR machine to detect?
5. Is it worth having it diagnosed by MB dealer then taking to an Indie, or is this something that an Indie can find straight away?
6. Estimate for cost of parts to rectify, and labour time.
7. Anything else I should ask to have done at the same time? eg change the auxilliary drive belt?
8. Any other advice from folks who have had this issue, or know about it?
Thanks for your assistance....Phil
Uncle Benz
West Sussex
Mainly Mercedes
Could be the intercooler pump. Mine failed at 30,000 miles. Symptoms similar to yours. If you poodled around, the power would return for a bit, but I think my pump was still running a bit at times, and then completely stopping at others. If you get the car on a Star, you are looking for a fault that reads something like "IAT implausible value" (Intake Air Temperature) if the pump is faulty. It is possible to listen for it running, but TBH unless you have already heard the normal running state it is hard to tell if it sounds right or not. It is pretty quiet even when OK. The pump is located in the bumper void ahead of the drivers front wheel. The pump is electric - not belt driven. You are unlikely to damage anything by driving it - the ecu cuts the 'charger to protect the engine, but I would really only drive it to a garage. Personally I would look for an indie with experience of V6 or V8 Kompressor engines, as the system is unique to these cars. Even main dealers with no experience can struggle with this fault occasionally.
sailorP
North Herefordshire
SLK32AMG
Col, I'm in Leatherhead, which must be a couple of hours from you?
Uncle Benz, I was thinking of using SS Motors in Weybridge, as they are the nearest Indie recommended on this forum. Based on what you said, I'd better ask if they know V6 Merc compressor engines.
Uncle Benz
West Sussex
Mainly Mercedes
Damn, drove past you today on the way to MB World. Could have popped round with the machine!!! If you can't get any joy locally drop me a PM and I could meet you halfway maybe...
colechelle
Resigned
your only a hour if that away from me, off tueday if you want to have a run down! im only 15mile from basinstoke!
sailorP
North Herefordshire
SLK32AMG
Thanks both
Would love to meet but I've no vacation left until next year so can't take time off in the week....it's evenings or weekends for me until January.
Sounds like I need to have it diagnosed by someone who knows these cars.
Star machine at local MB dealers, then ring round the Indies for quotes for fitting? Unless either of you can meet up one evening?
sailorP
North Herefordshire
SLK32AMG
My wfe can drive down
Col,
My wife can bring the car down to Andover on Tuesday.
She hates driving it, and is not mechanically minded at all.
This would be so you could diagnose/confirm the problem on your STAR machine?....or do you offer a fixing service too?
If so, what's your postcode?
colechelle
Resigned
Just as an update, had phils car here today, charge cooler pump u,s, only a stored fault at the time but been logged 38 times!! guess we will have to wait and see if uncle benz sorts it for him or he takes it into MB!!
sailorP
North Herefordshire
SLK32AMG
Well, many thanks to Cole for finding the fault.
MB Epsom say 5 to 10 days for the pump to come from Germany, and its 260squid plus two hours labour.
Seems I also have 'failure of CAN low at module N10-1' several times too, whatever that means.
Does Uncle Benz work Saturdays?
colechelle
Resigned
As i said in the pm Phil, dont worry about the CAN low fault, it cleared stright away!!........and ah, how about giving her a wash
sailorP
North Herefordshire
SLK32AMG
Cheeky.
Yeah, I know she's filthy.
Two weekends spent working out of the country, and several motorway drives in between, plus I won't let anyone else clean her.
There's a handwash centre here in Leatherhead that everyone says is great, but I've seen them drop their cloths, pick them up and start washing again after a cursory flick to get the grit off. Not on my car you dont!
This weekend, I promise.....I don't even need to convince myself as I like doing it.
racall
london
c class and slk
You wont go far wrong with those hampshire lads.
sailorP
North Herefordshire
SLK32AMG
  • #19
Booked in with Uncle Benz Saturday.
I'll be making the tea while the pump is changed.
Winter woolies on....standing round in a workshop with the cold weather coming.
BlackC55
South coast
C43
Very common issue that one.
I have done a coulple in my shop and when I was at a dealer. Make sure you also replace the relay.
