SOS "Brake check light"
allmerc
West Sussex
2004 CLK270CDI
Hi guys, me again. My c180 tonight on the way home, check brake/go to garage light came on. I had a MOT last month and it passed without anything needing work. As the light came on I noticed my speedometer went and sat at ZERO and didn't move and also accelaration from stand still went out the window. I am worried that maybe my ECU has gone haywire since I removed it last week to clean in order to clear that eng RPM hunting problem. I need your advice please. EJ
You have lost a speed signal some where,,seems like a poor connection still
allmerc
allmerc
West Sussex
2004 CLK270CDI
Hi Malcolm, about 2 wks ago in trying to fix my previous problem, I changed the Cam sensor with the wire extension, also took the ECU out and cleaned it and put it back. The Air mess sensor was also pulled, cleaned and put back. Where would you say I should start looking at this speed signal lost? is it safe to drive it as it is to a garage?
Its perfectly safe to drive it and you will not make anything worse,,is it the ABS lamp on
allmerc
allmerc
West Sussex
2004 CLK270CDI
yes, the ABS lamp in a triangle on the tacometer side is on...Very very slugish acceleraion from stop and hardly any speed afterwards and speedometer stays on Zero.
OK then just a missing speed signal I cant remember what papers I sent you if any
allmerc
allmerc
West Sussex
2004 CLK270CDI
I don't recall if you sent me any papers at all. I was suggested to replace the camshaft sensor and the wiring lead that its attached to it since the oil leak had gone to the engine loom, AMS, O2 sesnor and ultimately ECU. I replaced the cam sensor and its wires (found the plug very tight and difficult to click back on) but managed somehow with unease. Cleaned AMS and ECU with the carburator cleaner spray and replaced O2 sensor...Problem seemed rectified and now this.
OK I will see what I can find,,its too late tonight what year is the car please
allmerc
allmerc
West Sussex
2004 CLK270CDI
Thanks malcolm, its a 2001, C180, 2.o Ltr, auto Y218 VGN
A 203 yes sorry about all this
allmerc
allmerc
West Sussex
2004 CLK270CDI
hey, at least i have you guys to thank for...A car is a machine and machines do break down...the irony of it is that i am looking to replace it ASAP but haven't found anything nearby for my budget of 10K. I am looking for a C230/C240 or C320..By the way, is the C270 CDI (5 Cylinder) any good???
SpikeUK
Hampshire, UK
"..By the way, is the C270 CDI (5 Cylinder) any good??? "
It is beautiful. Smooth, powerful and very economical.
If you chip it, it is also pretty rapid.
The 270 plus 5 speed auto is definitely one of the best Mercedes combinations.....
allmerc
allmerc
West Sussex
2004 CLK270CDI
Well, Andy, good of you to say so...Just paid a deposit on a 04 CLX270 CDI, I simply loved it at first sight. Will have a pic up on here when I pick it up on Friday.
Cole@MBS
www.mbssouthampton.co.uk
Do you mean a CLK270CDI??
Good car,nice power output and not a lot of faults!!
allmerc
allmerc
West Sussex
2004 CLK270CDI
ooops, yes, thats what I meant. Faults? hahaha, what faults am I gonna get into now?
allmerc
allmerc
West Sussex
2004 CLK270CDI
I think I had my share of faults with my "Friady's" C180. I really need a break.
allmerc
allmerc
West Sussex
2004 CLK270CDI
  • #18
Sam, rest assured if and when any fault comes up, you will know right away. I really appreciate your help and others over the past year with my C180.
Cole@MBS
Its what the forum is here for Sir!!
You wont have to many probs with a clk of that age, most of the common faults would have been delt with!!
He has lost his speed signal,,no speedo and ABS up
