Spark Plug Change on CLK430
Mark A
Aberdeen
58 ML-320CDI.
I am just about to change the spark plugs on my W208 CLK430 Convertible. The plugs at the front look easy enough to get to, but I am a bit concerned about access to the plugs at the back. The ones on the passenger side look just about impossible to get access to. Any tips before I have a go - would be greatly appreciated. Also planning on changing all the plug leads at the same time.
Mark
Cole@MBS
www.mbssouthampton.co.uk
Have a good box of plasters handy!!!!
There not that bad to do once you get started!!!
bigasotonuk
Southampton UK
C43/55 AMG 1999 / C230K 1997
There a lot easier than they look honestly, I have seen someone change them in less than 25 minutes, though that was with an air ratchet, and as SAM says you will graze you knuckles.
Have you costed the leads yet? Expect to pay well over £100 for a set.
M
Mark A
Aberdeen
58 ML-320CDI.
Many thanks for the replies. I have ordered a set from ECP +/- £139 better than the £400 (£25 each) that MB wanted. I ordered the plugs from ECP a few weeks ago and was pleasantly surprised when the cheap Beru plugs turned out to be Bosch.
I hope to get into it over the weekend - fingers crossed & plasters on standby.
Mark
It is best to lever off the plug caps using an 17mm open ended spanner over the top of the cylinder head, this will stop any damage to the coil packs.
I will have to change mine soon
M
Mark A
Aberdeen
58 ML-320CDI.
Many thanks for the advice guys.
I bit the bullet last night and did it. I was very surprised at how good the access was once I had got the coil packs out of the road. All 16 plugs, leads and 1 coil pack changed using parts from ECP - purring like a good un now.
Mark
turbopete
Spennymoor
2018 '18' Ford Edge tdci biturbo (sorry)
16 plugs???? what the hell is under the bonnet????? or are they now putting 2 plugs per cylinder in a V8??? seems a bit pointless that though.....
jberks
The V6s and V8s have been twin spark for a fair while now. Merc just don't shout about it - unlike Alfa Romeo ;-)
turbopete
Spennymoor
well i always wanted a V8 AMG! but it sounds like i would need a mortgage to keep 1 in spark plugs, never mind petrol! :lol::lol::lol::lol:
im glad i have to run diesels now! i couldnt afford a merc if it was petrol!!!!!!
