Sparkplugs and Coil packs
TheBlimp75
Milton Keynes
2005 CLS 350 107k
Is there any requirement to change the coil packs when changing the spark plugs.
Just wondering if it makes much difference.
Thanks in advance
Sent from my SM-N960F using Tapatalk
Thanks in advance
Not unless there is a fault buddy :D
Botus
S500/2010/500
2005 CLS 350 107k if its this car I could see its already on its second set...
mine uses the same coil packs as the petrol v6 and 3 have died, being 2 years newer and half the mileage
DSK
CLS 320 CDI, S350 Bluetec
Generally no. However, these do wear down with age and I change mine around every 100,000 miles to ensure they are in optimum condition. They do wear down with age and despite a car seemingly to run fine, they won't be at their best under load etc.
E.g, the Volvos run spot on but, once new coil packs were installed as part of my persoanl preventative maintenance schedule the car's throttle response, sustained performance under full throttle/boost was marginally better. To me this means a lot and also avoids odd issues due to age/wear, to many its not worth the cost of coil packs until they fail outright.
However, I will always say, if/when you change them, change the entire lot at the same time.
