Sprinter 213 poor starting
SpeedyKTM
New Registration
I Have an '03 Sprinter 213, owned from new and 87K under its wheels.
It has become a terrible starter, either hot or cold.
Spins over fast enough but no life. Have tried an extra battery via jump leads and this has sometimes helped.
Heater plug current draw is good.
Had it to MB who found a small air leak, but the repair has made no difference.
They suggest a leak test on the injectors, but can't be sure this will fix it.
Once started, it flies, but switching off, even for 2 minutes means reaching for the easy start.
What's your opinion?
Regards
SpeedyKTM
dava
The Toon
Injectors, if it starts on sniff it's not maintaining it's pressure. You need some one to put a test on each to see which one it is.
f v swindells
had a similar thing happen to my 52 311cdi mb dealers put new seals on the injectors or common rail thing anyway 45 quid all done
chris heap
east yorkshire. village called keyingham
bad starting
sounds as though injectors 1 or 2 of them my have a bad leakoff needs a leakoff test,also at the back of the common rail is the rail pressure sensor. sometimes a small peice of the o ring comesaway and can cause this problem as it gets worse can cause engine to cut out. hope this helps.chris.
