Sprinter 311 CDI Cutting Out
andysprinter
Hi Everyone,
I have a huge problem with my sprinter. It keeps cutting out on me. When it does so,sometimes it starts straight away,other times i need recovering. I have had a replacement ECU,Fuseboard,Wiring Loom from ECU to Engine,Ignition Module all to no avail. The garage i take it to i trust as i have known the owner for 15 years. When he plugs it in the reading is " Capacitor 1 under voltage". He believes it is an electrical problem but cant quite get to the bottom of it. Today im told it could be 1 wire from the ecu to the dash that when is cut the reading fault is the same.
Can anyone shed any light on this whatsoever,as i run a small business and as im sure everyone is aware , the economic climate isnt that good!!
Any help or idea would be most helpful..
Andy
BlackC55
South coast
C43
You need to have it code read with a Star as some diagnostic readers will not show up all codes.
A
andysprinter
Thanks for the replies!!
It has been read with a star machine.
What is the cps?
Andy
shayes
as stated
Crankshaft Position Sensor
Many a thread on this culprit from Malcolm.
the CPS fails most often when the engine is warm / hot, then restart some 20 mins or so later, sometimes it will fail all together. the engine will crank, but not fire up.
£47 from a bosch service center
A
andysprinter
Thanks for all the replies/suggestions. Deffo not the injectors...had all 4 changed in Jan. CPS been tested..not that either. Changed a 2.5mm wire from behind the dash today that seems to have been building resistance.
Every sensor/valve seems to be ok and narrowed things down to this wire!!
Let you know...
Andy
surlyoldbill
New Registration
Let you know...
Andy
Can you share details about WHICH wire it was? Like, what it was connected to, color, location, etc.
I have been having the same problem, and would like to find a solution.
tomharland
New Registration
Sprinter electrical problem
Has anyone identified this wire, its significance and colour?
cheers
Tom
Bonehead
Bristol
Sprinter 311cdi/2003/2.1L turbo
andysprinter did you ever get to the route of this problem? I am having the exact same issue and not sure what to do.
