sprinter 316 black smoke
ray100655
sprinter 316 2011 with om651 engine
having a few issues with my sprinter 316 it has the om651 engine, every few days eml comes on with nox exceedance egr shut down
i can get the eml off but code is still there i can still do 60 on motorway but with some black smoke. i was going to clean the egr but it is at the back of the engine
does anyone know if there is a pipe i can access to spray the egr cleaner into i have changed the pre cat oxygen sensor is there any more i should change there has been an improvment since i changed the sensor
Frontstep
T210 320cdi
Some people like these sort of things;
Still doesn't fix poor injectors etc.
oigle
members.optusnet.com.au
It is possible that your egr valve is not closing properly - sticking. This can be caused by carbon buildup or chatter marks on the piston. A valve stuck just slightly open will cause lots of black smoke and obviously upset your Nox readings at same time.
Kev555
N.I
You can get EGR cleaner you apply through the air inlet. not sure if its as good as strip down and clean. As frontstep above recommended sea foam but check your codes(diagnostic) in case EGR is faulty or something else. The cat is better taken off to clean properly. you can get additive to apply through the 02 sensor holes but never heard it does a lasting job. I took mine off and cut the pipe each side of it and soaked it overnight in Wynns DPF cleaner and then power washed it.
R
ray100655
thanks for the replies i am still trying to sort out several issues with my van agin i need some help have used 2 cans of on car dpf cleaner and that made it run better but i can't get rid of the nox exceedance error as fast as i erase code it's back
so today i went under the van to find the nox sensor only to find there is'nt one i have changed the oxygen sensor the one nearest the turbo the only otther sensor i can see and cleaned has a long probe into the dpf part so i don't know where else to look as there are no more sensors on the exhaust that match what a nox sensor looks like
i have another couple of questions but i will start a new thread
Kev555
N.I
There is only two sensors on the exhaust. one in the cat and one in the DPF. If regens aren't happening or Dpf is could be the 02 sensor. Best to get a proper diagnostic with an independent or you could be spending money replacing parts and no difference. Black smoke could also be a sign of over fuelling and that could be a faulty injector or temp sensor. So many things you could replace before curing it so thats why you'd be better getting a session on star diagnostics as it could potentially save you a lot of money. Start with the simple stuff first if you cant avail of a diagnostic session as oigle said, clean your EGR valve. EGR cleaner available in cans at you local motor factors.
R
ray100655
thanks gonna spend a few hours tomorrow to try and sort some of the stuff out looks like scan with a proper tool to iron out the faults
i do know that no2 glow plug is faulty as the glow plug light comes on while driving
