Sprinter engine removal
chg
Hi i know this is mostly a car forum but ive seen quite a few van questions. Basically i have a 308d and need to get the engine out. I have stripped the whole front panel down so im now left with the engine sat there but not quite sure how to remove it. Any help would be appreciated.
:D
With a engine lift is the only safe method, you can hire them for the day,
Welcome to the forums!
I have quite a lot of sprinter info if you get stuck, and welcome.
C
chg
Many thanks for the welcomes. :D
My replacement engine actually turned up today and the guy had sent me the gearbox, starter and powersteering pump aswell FOC which was brilliant of him. I do run a garage which its name is the initial of my username :D We dont work on anything this size hardly at all and the only thing i have had to do on my sprinter before was the clutch.
We got the whole lump out in one. Took my clutch out and the donor engines clutch out only to find the donor engine ones was better which surprised me as ive only done 12k on my clutch LOL.
Got the engine back in today, used my gearbox, donor clutch, donor slave cylinder as mine was leaking when i removed it!, my power steering pump, my glow plugs, and the donor inlet as the throttle linkage had less play in it than mine.
One question though, How on earth do i remove the plastic fan? as the donor one has a blade broken :(
if i remember correctly, the blades are held on to the viscous hub with about 8 small bolts. cant be sure but i think theyre allen key type bolts. im sure someone will be ableto confirm this 1 way or the other. i havent seen one for about 7 years!!!
