Squeak ...
col320ce
Australia
320CE Sportline
1993 320CE W124 Sportline
Has a repetative squeak that tends to stop when you take your foot off the accelerator. The cycle of the squeak is independent of engine speed but seems like it might be too slow to be the turning of a wheel. A bit hard to tell where it is comming from. Is this 'classic' for anything? Where should I start?
Thanks ...
Can you reproduce the squeak with the bonnet open
col320ce
col320ce
Australia
320CE Sportline
I don't think so ... I will double check tomorrow though.
It does not occur when still, only when accelerating but I will check it does not start when I rev the motor.
Then have someone in the car with the foot brake applied,and put it in D you can give it a little throttle, and maybe find where the squeak is
col320ce
col320ce
Australia
320CE Sportline
Tried above but I can't hear the sound unless the car is moving ...
col320ce
col320ce
Australia
320CE Sportline
i own the car ... is tha what you mean?
roscoc180
Cornwall
R230 SL350 black/blue-2004
I had a very annoying squeak on my sl, took me weeks to find out what it was. Checked everything on the suspension e.t.c, turned out much to my annoyance to be the bonnet catches. Fingerful of grease in each one sorted.
Ross
have you tried it with the fan turned to 0?
col320ce
col320ce
Australia
320CE Sportline
I've rulled out the internal blower fan ...
I will jack it up and have a look at the wheels ... at some point ...
C
C180 Chris
Does it get louder when you have lots of gizmo's on ie, heated seats, window, steering wheel or heated screens (high current draw)
I am thinking Alternator noise that gets worse if you put a lot of drain on it?
col320ce
col320ce
Australia
320CE Sportline
I'll check that out - though would the noise cycle vary with engine speed?
