Hi everyone.
Can any one offer any advece . I have a minor problem on a 1998 CLK 200. 37,000 miles. Just recently I noticed a bit of a squeek coming from the auxillary / serpentine belt. It was altered by turning air con on and off. Changed the belt and it made no difference. Stuck a stethascope on the tensioner pulley and the noise was identified as coming from that area. The pulley wheel itself is as free as a bird and does not rumble, but the tensioner squeeks when you move it to release the belt. On closer examination you can see the tensioner moving slightly when you move the steering wheel or turn the air con off. the noise seems to be on the pivot point of the tensioner itself. Can I lubricate it or spray it with something to stop the noise or is the only answer to renew the tensioner. If so how much are they. ??
Thanks John.
Thanks John.
