SRS warning and passenger seat not moving
tim091
Oxford
CL500 2001
SRS stays illuminated on the instrument cluster and the passenger seat no longer moves when I lift the handle to let someone into the back. Both these started happening yesterday so my assumption is there is a connection.
Any thoughts?
Passenger seat moves ok with controls on the door, it is just the auto sliding back and forth by lifting the handle that does nothing.
This could be a broken wire in the seat, we had the same thing earlier this year on another. When you find the fault it may need STAR to turn off the SRS lamp
T
tim091
Oxford
CL500 2001
Thanks Television, I will have a look at any wiring in the seat I can find.
The back should just come off easily with 2 screws at the bottom, and it slides off
Steve@Avantgarde
Bristol/Somerset
The wiring that goes around the seat back is a classic failure on the W215. Normally you get the warning in the cluster that the seat is not locked in.
