SRS warning on after changing Radio 10 to aftermarket head unit
Liberator
E320 CDi 2005 (648 961)
Today I swapped out the Radio 10 on my 2002 C200 K coupe for an Xtrons Android 8.0 inch head unit. Everything went fine but I obviously had to disconnect the centre console which includes the airbag off warning lamp. I noticed whilst fitting the unit that the SRS warning was on but once I reconnected the console the warning was off.
When almost finished, I had to turn the car around to get access to the passenger side and I did this with the console disconnected and of course the SRS warning was on. I then reconnected everything only to find that the SRS warning remained on :( .
From reading other threads here and on other forums I have concluded that the SRS warning has to be reset. Is there anything else I can try? If not, does anyone know of a location in the Southampton area where I can get the warning reset without it costing an arm and a leg?
I appreciate your informed replies!
McDonald
Surrey
SL500 2004
MBS in Southampton are really helpful Mercedes specialists
AnthonyUK
Alton, Hants
C240 estate 2002
I can do it if you fancy a drive over otherwise there is an indy in Horndean.
mercmancdi
templepatrick - co antrim
www.schnauzersinireland.com
2009 E250 cdi 08 cls320 cdi ,2007 e280 cdi '2005 E 280 CDI ,VW TOUAREG ,JAGUAR S AND xTO NAME A FEW
Is there any possibility it would correct it’s self after a short drive. , or am I thinking of steering wheel after working at it.
onefortheroad
uk.
for future reference dissconnect the battery when workng on anything that includeS SRS.
Liberator
Liberator
Thank you all for your replies, especially @AnthonyUK with your kind offer. My local garage who I have used for many years were able to do it using a Snap-on Diagnostic Tool. Took about 2 minutes, done while I waited!
AnthonyUK
Alton, Hants
C240 estate 2002
Phew. That good to hear you have resolved it.
I did exactly the same thing so bought an iCarsoft i980 which is able to reset this.
Liberator
Liberator
I've had a look around at tools to enable me to do similarly but they all seem limited in functionality and expensive. I was impressed by the Snap-on diagnostic unit that my local guy used - until I looked at the price! This is the first Mercedes that I have owned and I'm not too sure yet how much DIY I am likely to undertake with it so maybe I'll wait and see...
www.W140.co.uk&www.r129.co
