dose anyone know of a stand alone ecu for a gearbox on a w210 e300dt I have changed the pump and it changes gear harshly if anyone can point me in the right direction or have any thoughts please
So I presume you now have a manual pump (om603 ) . So you do not use the throttle potentiometer any more, now I may be completely wrong but if you could keep the throttle pot being worked by another cable then would this stop the harsh gear changes as the ecu is now getting throttle position input ??
The original throttle cable connected up with the throttle pot ( potentiometer) . The cable pulled on the pot and this then let the engine ecu know how much pedal you were using / pedal travel.
Look under bonnet about a foot in front of wind screen drivers side and you will see it.
Stop looking for the Best Garage!! We are here
and have the best advanced solutions for you,
at Competitive prices.
Put us to test with any issue you may have.
