Starter relay ....where is it ????
Smoo
Hi, can anyone tell me where the starter motor ' crank' relay is located on a w210 E300 TD 1999 Yr ( non cdi) .
I want to be able to crank the engine without injecting any fuel .
Or alternatively , how can I disable the injector pump ??
Thanks in advance
you could remove the fuel lift fus from the pump but this would empty the system.
If you take out the ECU fuse then the engine will not crank
See what someone else comes up with
turbopete
Spennymoor
2018 '18' Ford Edge tdci biturbo (sorry)
pull the 4 wire plug off the fuel shut off valve. if you can reach it without removing the inlet manifold, that would be the easiest way, in my opinion. thats the way id do it anyhow
Smoo
Yep, I have done it this way ..... but it does bring up an " EPC Engine electronics " message on the display, however it cleared after a couple of proper starts.
turbopete
Spennymoor
i cant even remember mine bringing that up on the display when i did it! glad you got sorted with whatever it was you were trying to do!
