Starting problem with 313cdi sprinter
jamin
Hello Ive got a 313cdi sprinter i had a major problem with the van and took it to a garage they replaced two injectors and it cured it but latley its had a issue with cold starts any ideas????? its driving me mad! oh and ive already changed the glow plugs! thanx
jamin
djweeble
Norway
Is the glow plug warning light coming on and staying on ?
A good place to start is the inlet temperature sensor, according to the workshop manual it should read about 6000 (6K) ohms at 20C.
I had a problem with the light staying on, I removed the sensor and found it was covered in crap, I cleaned it, problem went away.
jamin
no the glow plug light dosent stay on. just comes on for a bit then it goes off when it finaly starts. ive had them all replaced about a month ago. any other ideas? thanx
jamin
i would also add it fine once its been runnin for 20 mins it will start every time i wonder weather its loosing pressure with a seal or somthing, so far ive replaced 2 injectors and had the rail pressure regulator replaced aswell
dava
The Toon
Try a Rail pressure regulator seal: 013 997 60 45 £0.60p
Or a regulator, bit more: 611 078 01 49 At the end of the pressure rail held in with two torx screws.
Also the valve on the top of the fuel filter: 611 078 02 49 About £2.00 ish.
Try starting it on sniff, (aero start) if it fires it suggests fuel.
jamin
ive had all of that replaced, alredy but the bloke who done it was a arse and charged me the earth for that and one injetor! bitch, also when its running and in traffic for a while it pumps whiteish smoke out is that related?
dava
The Toon
Well if you've had all that done and it's right, it must be an injector. The white smoke is excessive fuel, do a proper spill port test and find out which one is leaking and either replace it or get it serviced. It's a common fault but at £400 each it's an expensive repair.
jamin
thanks mate i can get injectors new for £150, i think i mite try and replace the valve on the top of the filter again see what happens, thanks for you advice will let you know what happens in due corse.
jamin
dava
The Toon
If you have not changed it do it for the small cost, they allow the fuel to drain back when they are faulty.
