Starting problems with my C240
Status
Not open for further replies.
csaw
Essex
I am looking for any ideas that my be causing this. Occasionaly when I try to start the car it turns over for a second or less then stops, sometimes it will do it several times in a row, sometimes it will start on the second go. This problem occurs if the engine is hot or cold, or if the weather is dry or wet. I had it fixed once under warranty 18 months ago, they put it down to the "ME board" which was replaced, although they admitted this was only a guess as they could not reproduce the fault. The car is a '97 C240. Anyone got an ideas??
Thanks.
piestore
manchester
POOR START
Sounds like the usual 112 engine problem, it can usually be identified by listening to the engine while starting, if it has a squeaky hi pitch tone you need to apply some special "starter ring grease" only takes about 10 minutes on a ramp.
C
csaw
Essex
poor starting
Thanks piestore, hopefully you have got me moving in the right direction. I have just turned the car over and it does have that high pitch squeal you mentioned. Funny, i had noticed it before and hadnt given it a thought as it has been there since i bought the car.
Chris
Status
