Strange noise
Sheeplover
I may be clutching at straws here, but my 1990 E260, has, in the last couple of days, started to "judder" when I steer to the left. It sounds like its coming from the back of the car. There is nothing visibly obvious that I can see.
Has anyone else experienced this?
The reason I ask is because if its something simple or silly [I'm not very mechanically minded!] then I'd be interested to know, and avoid paying out any $$$
Thanks,
Sheep
Myros
R107, S211, R170, C219
only forwards?
or in reverse as well?
Are you hanging on to the steering wheel well onto its stops, or are you just using a light grip?
All speeds, or just manoevering?
Not that I know why, but this info will help the others here work it out.
Sheeplover
"or in reverse as well?
Not that I know why, but this info will help the others here work it out"
It appears to be only going forward.
I wouldn't say I grip the steering wheel and harder than just holding onto it.
Would appear to be at most speeds whilst turning left, ie taking a left at traffic lights, which isn't very fast at all.
Myros
could be the wheel rubbing on the bodywork
or a bearing going, or cv joints, or the brakes messing about. I'm going to stop now as I'm getting scared. I think a trip to a good garagiste is in order. It could be dangerous. Check the wheelbolts for tightness before you go.
oleras
Limerick, Ireland.
Thanks,
Sheep
is it a judder or a knock ? reason i ask is, tie rod went in my previous car, ford focus, and it knocked when i turned left, although your noise is coming from the back, but something to think about ?
I'm thinking it maybe a wheel bearing starting to go. Mine makes a noise occasionally when turning left or exiting a roundabout. Diagnosed as wheel bearing starting to go.
Sheeplover
Thanks for everyones replies, appreciate it.
Gonna take it to a garage so will comeback with the outcome.
Cheers.
