Sudden loss of power + smoke coming out of exhaust
MBnewbie123
C-Class W204 2008 2 litre
I own a W204, if you need any more details about my car after reading this, please let me know.
Regularly, smoke is coming out of the exhaust and when I press the throttle down hard a lot of smoke comes out and it is black in colour.
The car seems to run okay, but then suddenly it will go into a mode where the ESP is deactivated and there is a sudden and drastic loss of power. It seems to happen when the car is being driven on motorways or dual-carriageways. I have not noticed the problem happen on B roads (I am in the UK) and the car is being driven at speeds similar to the speeds it is driven at on the motorway or dual-carriageway. I am able to maintain good speed in the car, but it is as if all torque has gone – maybe that is not the correct description.
On short drives where the average is about 20 mph, the car is fine – except for the smoke problem.
I brought it to a reputable Mercedes-Benz garage, and it was fixed, but the problem has come back.
I bought an OBD reader it showed the following fault codes:
POI 23 - Powertrain
Throttle/Pedal Position Sensor/Switch A Circuit
High Input
P2263 - powertrain
Turbo/Super Charger Boost System Performance
P2506 - powertrain
1) ECM/PCM power Input Signal Range/
Performance
P203A - Powertrain
P207C - Powertrain
P22E3 - Powertrain
P23E2 - Powertrain
P2638 - Powertrain
P0089 - Powertrain
P0087 – Powertrain
P0088 - Powertrain
Suction control valve stuck
P0340 - powertrain
Camshaft Position Sensor "A" Circuit (Bank 1 or
Single Sensor)
U0103 - Network
P0183 - Powertrain
Fuel Temperature Sensor A Circuit High Input
P200B - Powertrain
P2054 - Powertrain
Reductant Injector Circuit Low bank Unit 2
P210A - Powertrain
P22E2 – Powertrain
P22E7 - Powertrain
Torque Management Feedback Signal A Range/Performance
I appreciate that is a lot of information, but I want to work out the problem is, bring it to a mechanic, and get it fixed. Given the car starts, and for the most drives fine – I cannot help but think there is an easy solution to this. The smoke coming out the back may be unassociated, so I would appreciate it if someone could tell me how I could stop that.
Thanks in advance.
oigle
2003 ML270 sold but not forgotten. 2022 Kia EV6 GT Line RWD
Black smoke is caused by one thing only....too much fuel for the amount of air being ingested. Can be caused by a number of things. Split boost hose is one. Failed boost controller is another. There are no doubt others but those two are simple to check.
MBnewbie123
MBnewbie123
Thank you for the info. Based on the fault codes I inserted above, can you see any that might be indicating what is causing the smoke?
MBnewbie123
MBnewbie123
If a 'reputable MB garage' fixed it before why not go back and tell them the problem has returned
I would but they are very far away, and in a rural area. The guy has a swarm of MBs around him and apparently is great with them, but it is an awful inconvenience if I leave the car with him. £80 in taxis. I brought it to him thinking the problem would be solved. He assured me it was. Then it came back. I cannot help. but think it is a sensor or something trivial as the car drives fine... apart from the occasional sudden loss of power!
Taffy7hfa
Oxford
I doubt it's a sensor, if the ecu is putting the engine into lymp mode it likely has a genuine fault probably fuel system related, as Oigle has said it sounds like overfuelling but that could be caused by many many different things, your generic code reader won't help much it needs diagnosing using Star or similar by someone who knows what they are doing. Guesswork is pointless.
mioba
Nottingham and Köln
if you got a code reader and dont know how to use it - bin it.
let the mechanic do his job.
We could tell you many things, it could be a-z........ an experienced MB indy knows how to decipher codes, with live data and find the problem.
rf065
Grossbritannien
You say the car has a 2 litre engine, but I cannot see any 2008 models with an engine that size, so I'm assuming it's the 2.1 diesel?
If so, first thing I'd look for is a split in the intercooler hose, Difficult to spot sometimes when not under boost pressure, but a good starting point.
The most likely does seem to be boost leak, intermittent turbo issues going on the codes and symptoms. Faster roads put the car into a higher boost level so the ecu notices at this time.
