The old question: Summer vs All Season vs Winter tyres. What's your thinking?
Bodhi
Sheffield
C320 CDI W203
Before my Mercedes I had a top of the line Accord. Tyres were 215/45R 17 all around. I had fitted the CrossClimate+ and on winters I was happy to see other cars left behind when they couldn't climb a very easy hill to arrive home. Granted, snowy days are not THAT common. But what does happens a lot in the UK are icy roads, specially when most of the time you drive b roads in the countryside.
This is the reason I chose the Crossclimate+ instead of a better performance summer tyre for my Type R. And sure, I could have brake better in an emergency, or be faster in a trackday, but for everyday driving I couldn't find a difference that was relevant to me. After all, I like fast cars, but in my case they have to double as family cars.
My problem now is that I have 225/45/17 at the front and 245/40/17 at the back and there is no Crossclimate+ (or any other all weather tyre for that matter) in 245/40/17. So I will have to compromise. Either installing 235/45/17 or 245/45/17 at the back. None of these solutions is specially appealing to me, as the speedometer will be slightly off, and I'm not sure about clearance if I get 5 people in the car as the sidewalls will be taller with both tyres. With the 235 is closer to the standard, but I'm loosing traction. With the 245 I get the full traction but its even taller.
Anyway... that is my current conundrum...
I'm still interested to see what you all think about fitting specific tyres for the winter. Now, before you suggest it, no I do not have anywhere to put the winter tyres away during the summer, otherwise I would choose the best possible summer tyre and a regular winter tyre and swap them accordingly!
B
Bodhi
Sheffield
C320 CDI W203
  • #2
This is the average weather around where I live: https://www.holiday-weather.com/sheffield/averages/#chart-head-precipitation
And it has been proved without doubt that below 7 degree a summer tyre is loosing traction in wet/icy surfaces, making them potentially dangerous. So, at least 5 months a year and where I live, an all weather tyre is better than a summer tyre (as far as I can see).
onefortheroad
uk.
Me -2019 GLC 350 coupe AMG line. Mrs- 1.2 vauxhall Corsa 2021 ,orange with a black roof. .
Fit 225 45 17 all round.
Craiglxviii
Cambs UK
When/ where was it “proved beyond a doubt”...?
It’s the tyre temperature, not the ground or air temperature that is one of the determining factors, and that changes dependent on driving speed & duration.
B
Bodhi
Sheffield
C320 CDI W203
Have you seen the objective tests in the video? It's about environment temperature. Sure, tyre temperature is a variable, but as I said, I believe it's different when your commute is using a well maintained motorway or a road than having to deal with smaller b roads that are barely used and they get very icy.
Oh and don't get me wrong. I'm not trying to say that I know better than you. In fact, I am interested in knowing where your figures come from? Are there any studies about tyre temperature in the winter? tests about how much you have to drive and what speed in order for the tyre to be safe?
onefortheroad
uk.
I have been thinking about that one too. But the rear rims are wider... So... Unsure...
Its very doable. Even with wider rims .
Craiglxviii
Cambs UK
Yes I have. I’ve also conducted those tests. Moreover I worked for 5 years with the world’s 4th largest car maker actually studying exactly how stuff like this works, and tyre choice was always a prime subject due to the high customer visibility. So, not only have I been involved in ride & handling tests, I’ve worked with the design engineering and validation teams in looking at the results and then say with the engineering and marketability management teams making judgement on whether or not they’re ok to proceed. The engineering data is crystal clear, the key factor (NB NOT the only factor) defining grip is the temperature of the tyre material matrix. Air temperature is therefore contributory to that, but doesn’t define it.
There is a difference in commute vs B roads. Yes, definitely. But, how much of one’s journey is spent on frozen ungritted roads for how many contiguous days of the year?
Also, again to point out. Summer tyres are becoming increasingly more winterised as materials science improves. The others, not so much with I believe one exception.
B
Bodhi
Sheffield
C320 CDI W203
Thanks for the detailed answer. I would be interested in knowing which summer uhp tyres would be better in cold/damp potentially icy surfaces. Also interested in knowing the best way to get the tyre to a safer temperature before venturing in to icy roads (loads of black ice on them at some days).
keefysher
Hampshire
W166 GLE350AMG Line 3.0 2017. BMW Z3 2.8 1998.
Confused of Hampshire here :geek::rolleyes:o_O
Have you considered you are comparing apples with stairs between the two cars you mention. One is a fwd manual, the other is a rwd auto. The manual had 60mm less width of tread on the drive axle than the auto.
A couple of bags of sand in the boot and narrower tyres will sort you out :D:D as will driving to the conditions.
The range of sizes you quote give an outside diameter range of 24.5 mm
Not sure any tyres will save you hitting black ice :shock: at an inappropriate speed.
AnthonyUK
Alton, Hants
C240 estate 2002 and a Nissan Elgrand E51 ser.3
I do that currently on 8.5j rears and they fit fine. It is rumored that the 245/40 r17 CC+ will be available this year in UK
Craiglxviii
Cambs UK
Look for tyres with a high silica content. The Uniroyal Rainsport 3 I use have been excellent winter performers for this reason.
Ditto. We live at the bottom of a small hill and from a standing start it coped with a snowy road with no problems at all.
Rainsport 3s seem to be very good in my experience.
Very little of my driving is in temperature where the there is any significant benefit to winters and given we often drive in 30+ temperature in summer I can see no point in switching to any other tyre.
B
Bodhi
Sheffield
C320 CDI W203
How can I see which ones do have it? I like the F1 Supersport, decent price, decent performance.
B
Bodhi
Sheffield
C320 CDI W203
Or what about the Continental Sport Contact 6
robin.large
CLS C63 AMG 2013
Enough! Studded tyres are better by far
Sent from my ONEPLUS A5010 using Tapatalk
Just fit winters and run them all year , they are cheaper that fancy cross climates .
B
Bodhi
Sheffield
C320 CDI W203
  • #19
Well yes. But the compromise is too much. Have you seen the video I posted with detailed results? A winter tyre can be even dangerous in the summer.
B
Bodhi
Sheffield
C320 CDI W203
  • #20
Im afraid.. the rumour is unfounded :( I asked Michelin directly, this is their answer:
"Thank you for contacting Michelin Customer Care.
Regarding your query, I regret to inform you that the MICHELIN CrossClimate is not available in 245/40 R17 , at the moment and we do not have any plans to launch this tyre in this tyre size in the immediate future.
Please do not hesitate to contact us again if you have any further questions, we will be more than happy to help.
Kind Regards,
Elli
MICHELIN Customer Care"
