the wine and ebay 124 CE 24v - update
lanciaman
Aberdeenshire
E220 Cabrio (A124) - 1994
Had a go at getting some rust out the rear arches today. That was good fun. Will post a couple of pics under bodywork.
Seems to have an idling issue, cold or hot. Idles around 1000 revs at cold, but it isn't even, and when put into D it kind of bogs down so needs a bit of throttle. CPS has been checked and was just about 800 ohms (cold and warm). Mine has the MAS unit for the fuel pump relay but had it out and cleaned but it was not dirty.
So dense question for today - where is the OVP relay on it? 1990/H age.
thanks
:confused:
It should be under a plastic cover on the middle of the bulkhead
lanciaman
lanciaman
Aberdeenshire
off for a look! thanks Malcolm.:D
lanciaman
lanciaman
Aberdeenshire
Nope, definitely thick.....there is an ECU of some sort, then the MAS relay then the wiper gubbins..... see photo. Other side of wiper gubbins in brake master and then fuses and other relays (presumably in screwed down box under the screen, behind the fuses). :confused:
Help! please.....
Its 119 and around there somewhere
index.php
lanciaman
lanciaman
Aberdeenshire
thing is, I know what it looks like - yet I still can't see it!!!
I will take a look on WIS for you :D
I have sent you all the pictures as to where it is and it is where I said;)
macker64
Ireland
1997 W210 300 Td & 1991 W124 300CE 24V & 2001 W210 320CDI & W210 E200 1992 W124 300ce 24v sportline
Location of OVP Relay
Lanciaman,
Take a look at the attached photo of the OVP relay in my 1991 300ce 24v.
The OVP relay is located on the RHS of the attached photo. Its the metal housing with the red top. Its secured to a metal frame via one screw.
Regards,
lanciaman
lanciaman
Aberdeenshire
Thanks chaps. That is excellent. I didn't take the plastic cover off,only peeled it back.
Will have a look tomoorrow to see if it is looking dodgy.
cheers
Lindsay
cheers
Lindsay
You have to open it up or try the one from your SL
lanciaman
lanciaman
Aberdeenshire
shall do...see if it reveals anything.
.....SL doesn't have one......
cheers
Lindsay
