There is an internal fault in the Steering Angle Sensor
Armani.X
Mercedes c class 220 / W204
After had a warning regarding with the ESP and run flat indicator inoperative I just went to the guy with a Snap on Diagnostic tools and the reading is There is an internal fault with the Speed Angle sensor and I also buy the Icarsoft Cr Pro and the reading are the same. Any idea Guys? Thanks in Advavance.
Kind Regards,
If it can't be recalibrated it will need changing. It's in the back of the steering wheel.
A
Armani.X
I try to recalibrate but the code still in there? guys do you know how much it cost the Steering angle sensor? and can i possibly do it by my self?
mercmancdi
templepatrick - co antrim
www.schnauzersinireland.com
I have changed them on Vw , was simple enough just had put everything back in reverse as it came out and had reset after fitting but in a few I done a drive and turned steering fully round right to left a few time put light out. But as said these were Vw , But I am sure with a little advice you should be able to do it yourself, just remember to disconnect power etc and unplug air bag.
Someone will know your car better than me and hopefully come along with a bit of advice.
A
Armani.X
Hi Guys,
Any ideas how to remove this middle cover to replace the Steering angle sensor? Any would be much appreciated
Not familiar with that wheel but normally screws from behind.
A
Armani.X
Yea there are 2 screws under there but i don’t know if that is the right one to remove the air bag and get access to the steering angle sensor
A
Armani.X
Answer to the ESP and Run Flat inoperative is Steering Angle Sensor....
Thanks Guys!
