Throttle butterfly stop adjustement procedure
Status
Not open for further replies.
cc260E
I am the owner of a W124 260E 1988 and I am looking for the throttle butterfly stop adjustement procedure?
I would like to get that device properly set up, and cannot find the procedure.
thanks in advance.
C
cc260E
  • #2
thanks in advance.
Nobody has any idea ????,
C
cc260E
I tried to post a picture of it but was not successfull. I will try to explain.
On the throttle, outside at the end of the gaz linkage, there is a screw blocked by a nut. this screw is used to limit the opening of the throttle at idle.
I have changed that adjustment and would like to do it properly.
Warren Stevenson
Perth WESTERN AUSTRALIA
Hi there,
Idle stop screws generally never need adjusting, only the throttle body needs is to be cleaned with carby cleaner and lubricated with CRC or similar lubricant.
Do you have an idle problem ?
Regards,
Warren :D
C
cc260E
Warren Stevenson said:
Hi there,
Regards,
Warren :D
Thanks Warren,
Indeed you are right and I should have never touched it. But I did it some times ago to have a stable idle and before I new that it is sufficient to clean. But that is the past and now I would like to do it properly, so any method is very much welcomed and apparently nobody knows the method. I beleve there is one.
To clean the throttle body I removed it from the car so I am sure everything is clean.
Status
