throttle pedal is not operating smoothly
jbond1978
Silkeborg, Denmark
E220 CDi, classic, 2005 (W211.006)
Hi all,
Maybe I'm a bit pedantic, but the throttle pedal on my W202 (c250TD) is not as smooth as I would like it to feel... when slightly pressing it, it feels like it resist a tiny bit and then gives in - the same happens when releasing it slightly. I would very much like it to be smoother, and have a feeling that it just needs some lubricant somewhere, but as a newbie in the world of Mercedes, I have no clue as to where it would be a good idea to lubricate, and what lubricant I would need. Any ideas?
Best regards, Jens
turbopete
Spennymoor
2018 '18' Ford Edge tdci biturbo (sorry)
you could try squirting some silicone spray down the throttle cable, as its only short and goes from the pedal to an electronic unit near where the battery would be on most other cars,on the left hand side of the car if i remember correctly. the one i had was the same. however the car hadnt been used much by the owner before me. i just used the car and tolerated it and it came good with use! either that or i just stopped noticing it!
jbond1978
Silkeborg, Denmark
Thanks! I'll give it a go, but isn't the problem more likely to be around a hinge/joint/rotating part somewhere?
I don't think it's down to the previous driver not driving it, as it has been a taxi and has been loved and taken care of for almost 400kmiles :) ...It still starts and drives as a dream though, and has no noticeable flaws - other than a bit of rust.
All the best, Jens
teddycatkin
cheshire cheese country
Hi Ms Bond--Sounds like its catching on something or the cable is worn/frayed--if it goes worse its wise to get the cable checked in case it breaks altogether when your driving?
turbopete
Spennymoor
the only real pivot point to lubricate is at the bottom of the pedal. after the electrical box that the cable attaches to, its all 'fly by wire'. also at that mileage if the cable has been used a lot, (eg town traffic rather than motorway miles) that the plastic coating on the inner cable could be wearing out or worn through and that strands of wire from the inner cable are causing it to stick on the outer cable. could be worth replacing the cable.
Miffy
Bromley, London
CLK 320 CAB Elegance C208
Isnt silicon spray supposed to be a killer of certain components? safe alternatife is PTFE based lubricant spray
turbopete
Spennymoor
my mistake mark. youre right. however, given that they probably dont cost a fortune, i think id replace the cable and lubricate the pedal pivot. all should be fine then!
turbopete
Spennymoor
its a nylon against nylon problem yes. the outer cable is nylon inside, and the inner cable is protected by a film of nylon. this prevents strands fraying over time and sticking anyhow! to fit a steel cable would mean possibly having to get it made up for you. given that the one here is probably original and 400k miles old, i cant see any big problem with an original spec replacement to be honest
