Torque Wrench
grahamwoodward
Midlands
www.gwoodward.co.uk
W211 E320 (petrol) Avantgarde Saloon (2004); CL203 CLC180 Kompressor Sport (2008)
Hi. I want to buy a small torque wrench (TW) for use with torx screws and bolts on my Merc E320 (W211). It will be used mostly for interior parts, trim etc. My Torx set has quarter-inch drive. Most TWs on sale go down to around 30Nm min. Is that small enough for small items on modern cars? What is the best range?
I bought one a few years ago , Teng I think ? Goes from 5-30nm ish (1/4 “) , good for glow plugs , oil filter caps , i then have another for bigger suspension stuff,wheels,brakes etc that runs from 30-150nm ish ? (1/2”)
Neither are anything special make wise , but I’m only diy’ing my two cars
grahamwoodward
grahamwoodward
Midlands
www.gwoodward.co.uk
Wighty - Thanks. Amazon do a Draper 3/8" (10mm) drive with a range of 10Nm-80Nm for £30. This seems a good range - yes? Ignore that - reviews on Amazon are not good - recommend the Teng so will look again.
I still think you will need 2 in the end depending on what car jobs you do , I still think I’ve used settings as low as 5nm ? Also as high as 150nm on suspension ?
grahamwoodward
grahamwoodward
Midlands
www.gwoodward.co.uk
I Will buy a longer (more powerful) one for wheel bolts etc soon but at the moment only want one for trim items and small parts. Thanks for help. Keep safe.
mioba
Nottingham and Köln
OP you should get a lower one to 5 Nm.
I have seen those attachments you stick on the end of your wrench - any one and experience
ajlsl600
france
Frankly I find I don't Need tw for anything non critical based on 40 + yr experience but I have 4 for critical stuff along with adaptors, both ways 1/4,-3/4. But torx to me was snap off and others devising another way to force mechanics into more stuff and more space to store it. IMG_20201227_141652.jpg
Those torque wrenches in the box , I have the same make as my larger one (GS ) . Just checked it goes to 210nm .
The smaller Teng one is 5-23nm
ajlsl600
france
Should cover all yr needs .
Frontstep
T210 320cdi
GS mark is a voluntary certification mark for technical equipment.
grahamwoodward
grahamwoodward
Midlands
www.gwoodward.co.uk
Thanks Guys. Happy New Year to all.
Frankly I find I don't Need tw for anything non critical based on 40 + yr experience but I have 4 for critical stuff along with adaptors, both ways 1/4,-3/4. But torx to me was snap off and others devising another way to force mechanics into more stuff and more space to store it. View attachment 64369
Same, I use torque wrench for wheel bolts. Trim and small things is down to feel.
ajlsl600
france
I have a two ft knuckle bar for those I keep one in each car for just that.
I’ve a nice one that fits behind the passenger seat.
One thing that the OP should bear in mind is to wind the torque wrench back to ~0 once finished. They work on a spring so if left compressed they loose tension over time and therefore the setting is no longer correct.
ajlsl600
france
I call that my baseball bat.!!!! Bought after some scxxbags hassled me walkin home from.my folks in uk some yrs ago.
AMGeed
Poole, Dorset
1998/2001 W210 E280 x2 SOLD 2004 W211 E55 SOLD, 2014 E63 Biturbo SOLD .S204 C180K
No need for a torque wrench on wheel bolts.
Tighten it up until you fart, then give it another quarter turn. Perfect.
