TPMS question
Funkyboy
Liverpool
E250 w212 14 plate
Hi all,
If I buy a set of alloys already fitted with TPMS (second hand mercedes wheel's) will it work with my system or do different sensor's need coding in?
Depends on the system you have and what's fitted to the wheels.
There are two types of system used by MB.
One uses wheel speed sensors to look for a change in wheel rotational speed to detect a potential flat tyre and the other uses pressure sensors mounted inside the tyre.
If you have the latter are the wheels you're getting fitted with the same sensors as the wheels coming off?
anyweb
Sweden
www.niallbrady.com
c238,w120 (diesel)
TPMS sensors on wheels won't work unless your W212 has TPMS capability, and talking from experience, my 2013 W212 didn't come with TPMS, that said, maybe the facelift W212 did, I don't know, but it should be clearly obvious via your instrument cluster,
my C238 for example, has TPMS sensors on each wheel and the car puts up a warning mark on the instrument panel if non-tpms wheels are fitted,
the tpms sensor itself is fairly standard, but if you car isn't tpms capable then they'll do nothing...
F
Funkyboy
Liverpool
E250 w212 14 plate
My car already has it just trying to stop the faff of switching them over
Yes, after driving for a while, it will pick them up
cliff61
Lincoln
C250d 4-Matic Premium Plus Sport 2017
I have a 2017 C250 with TPMS and pressures can be read off the dashboard. If I fit another set of wheels with genuine MCB TMPS sensors fitted, you're saying the system will just work after driving for a while?
How does it pick up different sensors, but more importantly how does it know which sensor is where?
Manc Rick
Manchester
W213 E220 Premium +, 2017 with OM654.
Not sure, but it definitely does.
I presume the car looks for sensors wirelessly and as long as the new sensors emit a message, the car picks that message up. As for how it knows which wheel sensor is which, I have no idea.
They are not something that need coding.
There are tpms antennas in each wheel arch, so it looks at the signal strength to determine location.
www.W140.co.uk&www.r129.co
