traction control on 2002 cl500
grocher32
ireland
2002 cl500
anyone had issues turning off the esp on there merc ??? i want to see what the car is like wit the button turned off but noting happens when i press it . i no u cant fully turn it off but noting happens when i press the button !! does anyone know if the buttons give trouble or is there something else that could be the problem ??
It only partially turns the system off, never completely
G
grocher32
ireland
2002 cl500
thanks for the reply malcolm i understand that its doesnt fully turn it off but i would like to have all the buttons and switches working on the car . im just wondering if anyone has ever had to replace the button or something else that might cause the problem
Is there an LED in the switch thats tells if off
G
grocher32
ireland
2002 cl500
no there is no led on it but when you turn on the lights on the car it lights up like the rest of the buttons . there was some ice on the drive earlier and i got the wheels to spin a bit before the traction killed the spin and noticed no warning light started flashing so im starting to tink its more than just the switch maybe ill just take it to a dealer so they cant test the esp system
OK up to you, but I think that you will find it to be normal
Lexman8
Yorkshire, The French Alps & Quahog
CL500 (2001): Distronic, Bose, Keyless Go; Honda CR-V EX (2011)
With ESP on, even without flooring the pedal, I've managed to spin the rear wheels when setting off on wet roads a few times. It made me wonder just how effective traction control is on the CL especially as the handbook barely mentions traction but rather focuses on stability. I've had other cars where the traction control intervenes more quickly and to better effect.
With ESP turned off, the large yellow ESP warning lamp in the instrument cluster is permanently lit.
ESP is to do with stability and not traction, it corrects the car if it slews or breaks away
