Transmission issue with error code P0715
BRABUS R230
London
BRABUS SL55 K8 (R230), SL500 (R129), B Class B200 CDi, VW T5 Transporter.
I noticed that when I put my car in drive from neutral it engages with a hard jerk...almost as if my foot was on slightly on the accelerator while putting it in gear, but the rpm are at around 750 in neutral then drops to around 500 rpm when in gear.
My car is now stuck in "Limp mode" and remaining in second gear while driving, (I cannot change gear other than reverse) only with error code P0715, apparently this code relates to the transmission electronic plate speed sensor, (whatever that is. :confused:)
not sure if related but my problem started after having a new alternator fitted, and having the plug and pins replaced on the lead connecting to my long ago upgraded 82mm throttle body.
is this P0715 code indicating a big issue with my gearbox...is this speed sensor inside the gearbox...or could the problem be elsewhere? :(
just seen this. "P0715 Input/Turbine Speed Sensor Circuit Malfunction"
Steve@Avantgarde
Bristol/Somerset
Its thumping into gear because its in limp mode, that is what happens.
Was there any other codes stored besides that code? If that is the only fault code stored then I would say you have an issue with the electro plate. But looking at the actual values on STAR will tell you for sure.
BRABUS R230
BRABUS R230
London
P0715
Thanks for your reply Steve.
Because I had low voltage issues apparently caused by a faulty alternator I was told that there were pages and pages of various fault codes prior to the alternator replacement, these would have been cleared prior to me picking up the car I am sure.
To clear the initial code I received while driving home I used my code reader which is quite basic therefore cannot read or display all the codes, the P0715 it displays as "P7015 Unknown" (I had to look it up on the internet) even after clearing it, the management light comes back after a few seconds, but still with no gear change!
I managed to take it back to the independent Merc dealer last night so I am waiting to find out what THEY say...
We had another post recently where the plate failed shortly after battery problems, I cannot tie the 2 together but who knows
BRABUS R230
BRABUS R230
London
P0715 Update
Just finished speaking to the garage, they said that the cleared the fault, took the car for a test drive, checked the oil level (noticed it was slightly low) put some oil in, took it for another test drive....and all seems to be ok.
Going to pick it up now! :D:D:D
If low on fluid check that pilot bush on the side of the box
