Trickle charger
old man Logan
Kent
W210 e280 elegance
Good morning all,got a quick question ❓,I have a 1998 w210 e280 v6 ,I want to connect a trickle charger I believe there's a connection in the engine bay with a positive battery sign but I haven't got that so slightly unsure of connection location,also has any body know where I can buy a new/2nd hand plastic cover please
onefortheroad
uk.
Can't you find the battery ?
old man Logan
old man Logan
Kent
W210 e280 elegance
Battery is under the seat in the back,but where's the engine bay positive battery connection I think it is on the right but not sure as missing the plastic cover with battery positive on it
onefortheroad
uk.
sonic
Staffordshire
E350CDI, SLC250d, FJR 1300
Positive connection is normally left side of engine on E classes with a red cover which slides back.
Also a ground earth connection on the left strut inside the engine compartment.
Mine is wired up now.
EmilysDad
Bury Lancs
ML350
I suppose it depends on how you interpret left or right. Sitting in the car (which is the general convention), my battery jump start connections are on the right ;)
onefortheroad
uk.
My video along with bobcats diagram, shows exactly where they are
sonic
Staffordshire
Yes when sitting in the car.
old man Logan
old man Logan
Kent
W210 e280 elegance
Thanks so very much,as I said I appear to be missing the plastic cover,but I've managed to get one ,but trickle charger can now be connected cheers
Woodleigh
S213 - AMG E 53 - 4MATIC - Premium Plus - Night Edition - Mild Hybrid Estate.
This is the correct connection for a trickle charger on my S213.
Look for the red sliding cover and this is where you connect the positive (red) cable and the brass nut (earth) this is where you connect the negative (black) cable.
Hope this helps.
onefortheroad
uk.
This is the correct connection for a trickle charger on my S213; however, all Mercs are the same. Look for the red sliding cover and this is where you connect the positive (red) cable and the brass nut (earth) this is where you connect the negative (black) cable.
The w210 has 2 brass round pegs and a black cover on the live . The op has lost the cover so he didn't know which was + and - . Not All the same :cool:
old man Logan
old man Logan
Kent
W210 e280 elegance
Yup I never knew it was missing TBH until now
