Turbo rattle? OM651 W212
Christopher Martino
E220 2014 2.2
Hi all,
I have a strange metallic rattling on cold start for around 15-20 seconds, sounds identical to this:
The OP of the youtube video claims MB changed, and I quote "rattling noise coming from the turbo charged air bypass flap which is inside the aluminum air duct housing."
I suspect he's referring to either the wastegate or actuator.
Any experienced members have any idea what it's likely to be, I had the timing chain done on warranty about 6 months ago, so it's perfect in terms of the chain but now the warranty has ran out.
Thanks!
John Laidlaw
Wirral
Land Rover Discovery 4
Sounds like the chain again! If you hadn’t said it was done that’s exactly what I would have said . Maybe they did the chain and omitted to look at worn sprockets
Some of the Indy’s will be along shortly with their more incisive diagnosis
C
Christopher Martino
E220 2014 2.2
I've ruled out the chain, I've had a good listen on the block and there's no noise originating there, it's definitely something on the intake turbo side. I suspect it's most likely either a loose actuator clip, or worn wastegate. The OP noise on youtube is identical and they had something changed on the turbo side, so I'm confident it isn't chain related.
Bit of a bugger to diagnose!
John Laidlaw
Wirral
To be fair to myself I’m on a train which is noisy itself!
Turbo or wastegate would result in a certain degree of performance reduction - noticed anything ?
Might need a Star Diagnostic to avoid guess work
C
Christopher Martino
E220 2014 2.2
Absolutely nothing funny enough, I mean a E220 is no rocket ship by any means, but it's plentiful with torque. It's done it from the day I bought it and never gotten any worse.
Probably just being paranoid, just don't want it suddenly sh*tting the bed and throwing something down the intake
Monday
Surrey
SL400 2016, CLS350 2020
Totally different car and engine but I had a very similar start up rattle on a 2007 SL350. Awkward to diagnose as noise only lasted 10-15 sec from a total cold start. Turned out to be the oil pump - awkward to replace as well.
Sounds very much like chain noise to me....
malcolm E53 AMG
Did they replace the chain or just the chain tensioner and as said a worn chain usually means worn sprockets all this needs clarifying before doing anything else
John Laidlaw
Wirral
I’m struggling to see(hear) beyond that too Alex but the OP is convinced the chain has been dealt with- my worry is it has but not right or thoroughly
Potentially a failed tensioner if this has not been changed?
Easy enough to remove the belt and rule out any aux components making noise. Not much else left to rattle otherwise :)
John Laidlaw
Wirral
Agreed, needs looking at by a pro (like you for instance :))
Not sure where the Op resides....
C
Christopher Martino
E220 2014 2.2
Took it to Prestige Motorworks, in Newcastle (since they're around the corner from me) as I had two chuffing injectors that developed overnight. I asked them to investigate the rattle too while its in and they've confirmed its the turbo actuator just before the engine pulls vacuum on startup.
The actuator linkages rattle for a few seconds then it goes away.
Toumassa
Registered
C220 Avantgarde / W204 Phase 2 / BVA7 / 04-2012
Christopher, i’ve the same exact rattle coming from the air duct. Did you get repaired or what was the solution please?
For information, in my case the rattle starts after 15 seconds on cold engine start and keeps going for at least 4-5 minutes. It became like this after a recent CDI update by the dealer. Before it was doing during 30 seconds. Also if i put the gearbox to D it stops 3 seconds after. Can’t hear nothing on warn engine.
thanks
LAntunes
New Registration
C250 CDI COUPE
Hi. Do you have the problem solved? It was expensive? I have the same problem...
Ionut Gheorghe
C220, 2006, 2200
Hello, how did you solve the problem?
mioba
Nottingham and Köln
It seems it was just actuator rattle
