turbo rebuild recommendations
Wheeler3108
Cambridgeshire
C320cdi
Hello everyone
I have a problem with my turbo/actuator. I keep getting a juddering at about 3000 rpm. Sometimes it will go into limp mode. Sometimes not. I have been told I will need a new turbo by my garage. Codes read indicate a boost position sensor.
Obviously a new turbo is quite expensive.
My question is.. how good is a turbo rebuild/actuator repair and is it worth doing or should I bite the bullet and get a new turbo.
If it's worth getting my turbo repaired...who is good to use?
The car is a 2006 c320 3.0v6 cdi.
Turbo fitted 757608-0001 garret turbo with actuator number 268
Many thanks
Andy
sjh
Cumbria
S212 E350 CDI Blue eff AG
Turbo actuator
I had the exact same thing on my E 280 I got the turbo actuator rebuilt at a place in blackpool , get turbo off the test the whole turbo and service it and also rebuild the actuator and then send it back to you. It cost me £140 for the whole job and no problems since.
The problem is that the actuator has a plastic worm drive in it which wears away its basically got no teeth left on it. They did a great job.
Would recommend a repair.
jaymanek
Nuneaton, UK
www.mercland.com
Essex Turbo, reconditioned exchange is around £600 for the part. You MUST change the inlet port motor at the same time.
Their turbos as basically as new.
