Unleaded fuel: general information
Status
Not open for further replies.
AndyB
New Registration
I am not an expert but have recently purchased a 1982 w123 230E Auto.
There seemed to be much contradictory and confusing advice. I found an excellent article on the general use of Unleaded fuel here at http://www.pumaracing.co.uk/unlead01.htm. Here are some quotes:
There is no such thing as an engine where the valves and seats don't wear at all because these are after all heavily loaded components. What is really being asked here is "will the valve seats last an acceptable period of time on unleaded fuel?". The answer to that is really "acceptable to who?". It depends on the view about engine life that the OE manufacturer took in the first place.
Aluminium - Any modern aluminium head (let's say post 1975) will have inserts that are able to run on unleaded petrol, even when the OE manufacturer says it is unsuitable. What they mean by "unsuitable" is that they are unwilling to guarantee the same 200,000 mile or so service life that they would expect from a post 1989 engine. They do not mean that the engine will suddenly and immediately fail just because you run it on unleaded petrol. In practice it will have no impact on the average car owner at all given that very few people keep their cars that long. If you have an aluminium head from a major manufacturer (Ford, VW, Peugeot, Vauxhall, Fiat, BMW, Mercedes etc) then stop worrying and just run it on unleaded. The worst that can happen is that eventually, in 100,000 miles or so, the valve seats will have pitted enough to need recutting but by then the chances are that the rest of the engine will be worn out too. There is no way the inserts will just burn out though in the same way as can happen to plain cast iron.
The full article is there in the link above. I have contacted MB UK and they are getting back to me with the answer.
Leylandp76
London, UK
That is a very good and sensible point to make. I've heard similar comments in Jaguar forums.
I think the only note of caution is to ensure that the octane level is sufficient. In the UK this is no problem as our minimum standard is 95 RON in Unleaded. However some countries may run a lower octane unleaded, for example in my home country, Australia, 92 RON is the standard grade of Unleaded, with 95 RON Premium unleaded being sold at a higher price. If your octane level is too low (leaded or unleaded) then you can have pre-ignition problems resulting in the potential for cracking of pistons or heads.
LRP is really on the market for iron-headed cars which are increasingly rare in this day and age. Iron heads typically do not have hardened valve seats as the cast iron is (with leaded fuel) a fairly good valve seat material and the seat is therefore cut directly into the head. Aluminium alloy, now used in most modern engines, is too soft for valve seats, hence the insertion of hardened valve seats which are of a much higher quality and hardness than the cast iron in an iron head.
I have used ULP in my uncatalysed 88 Jaguar and now in my 87 300TE with absolutely no problems. There is even an argument that it will burn cleaner than LRP due to the reduced additives, but I have no empirical evidence for this.
lawrence lim
New Registration
hi Alistair,
like your advice. i just got a 92, 200e 8 valves in singapore. one machanic says that i should use 95 unleaded due to the old type of engines i had. another says i should use 98 unleaded for its a better petrol, maybe he mean better for my just overhaul engine? thanks
lawrence lim
lawrencelwk@yahoo.com
Status
