Unlock code for Navigation Console for languages
claireyfairey
I have 2 S320's, 2000. One of which's main console has all the languages avaliable. But i need some sort of code to unlock the second one, as it is stuck in German, and wont let me access the Language options.
does anyone know this code? or can you put me in touch with some one that does.
Go to "sys" then time and date and you have the language menu, press "sprache" and choose the English
Welcome to the forum
C
claireyfairey
thanks very much. the language bit is not letting me select it. need an unlock code.
There is no code for this, no comand units are coded, if it has locked up and all frozen, then pull fuses and it should re set
C
claireyfairey
thank you. will try it asap. and get back to you. much apreciated.:)
Alfie
Surrey/Cotswolds
www.comand.co.uk
You need to have the navigation disk in the system to load the language. then the option for SPRACHE will appear.
To get to this menu press SYS -> EINSTELLUNGEN -> SPRACHE
Golffather
Please excuse the intrusion but I can't send a pm to Alfie as i'm new so will post here if I may....
Basically I have a 2002 ML with Command and would like the newest possible nav disc. Can you let me know what I need and where I can get please?
Thanks and my apologies to the OP
Alfie sells them cheaper than anyone else,, the 2010 DX disc i think
www.ckinsurance.co.uk
