Urgent help SBC brakes
bembo449
gainsborough , lincolnshire
2003 211 , ive deactivated SBC using mb2 , but still cant get rear caliper back in to replace the pads , help
Open the bleed nipple before pushing pad back?
star
Reading
Smart + others :)
Siezed rear calliper?
bembo449
bembo449
I dont think so pal , passed its mot with no brake probs y.day
EmilysDad
Bury Lancs
ML350
could still be seized ... :confused:
You'e now trying to move the piston back to a place it's not been to since it last had new pads and as the piston has been extended for a while it could be rusty enough to not move back ....
bembo449
bembo449
Not sure what the issue was , took caliper off , put it in the vice , gave it a sharp tap with a hammer and it dropped back easy , very odd , thanks fir you thoughts guys
star
Reading
Smart + others :)
So it was seized or you were pushing piston back crooked pal. :)
Might now need a caliper overhaul kit ? If there is corrosion on the piston it could still stick again ?
ajlsl600
france
a sign would be one pad considerably more worn than the rest esp on that caliper if not so then having pushed it back yr likely good to go
