Vito 110CDi Clutch Problem
stevebo
My Vito 110 CDi on a W plate has just developed a fault. I lost abilty to select a gear with engine running.
I can select any gear with or without the clutch when the engine is turned off, as soon as the engine is running I cant select any gear. Then without any apparent differences it operates as normal, if I cut the engine and restart no gear selection is possible...
Desperately in need of any help or advice you can give ???
Thanks in anticipation
