Vito won’t start when warm
R4mos
Vito
Hi I’ve got a Mercedes Vito 2006 109 and it is very difficult to start when warm even from cold it can be hard to start , fuel filter , fuel rail & sensors , injectors,cam & crank sensors even ecu all been replaced but still the same please has anyone had this issue & cured it
mattkh
England
A160 W168 1999 1.6
Mileage..?
You dont mention glow plugs. Whats the story on those..?
R
R4mos
Vito
Sorry yes also replaced
R
R4mos
Vito
Milage 103000
Perished run back tubes always caused issues with poor hot starting.
I'm intrigued - what's a run back tube? Do you mean leak off pipes from injectors?
Yes, they can perish have small cracks in that let air bubbles in.
R
R4mos
Vito
Thanks for replies dont think it’s a compression fault as engine runs perfect once running
mattkh
England
A160 W168 1999 1.6
Fully charge the batteries and see if it makes any difference.
R
R4mos
Vito
Ok I’ll charge battery but van can be stood for weeks & starts up better than when it’s warm
mattkh
England
A160 W168 1999 1.6
Thanks.
Do you know the engine code..?
R
R4mos
Vito
Got the engine number if this helps
64698151275731 can try & get code tomorrow
mattkh
England
A160 W168 1999 1.6
Thanks. The first 3 numbers above is the engine code.
Its a OM646.
R
R4mos
Vito
Yes
mattkh
England
A160 W168 1999 1.6
Thank you.
Please put up a picture if you can. Apparently, on your car engine, they have to be the ceramic ones. I do not know if I can tell the difference between the two types.
R
R4mos
Vito
  • #18
Ok I will get a photo but the ones I took out were original merc ones which I assume were correct & by replacing them it hasn’t made any difference at all to hot starting
mattkh
England
A160 W168 1999 1.6
Thanks. Are the replacement ones also Mercs..?
