W114 1973 280CE Coupe problem, fuel?
Skylinepilot
Hello,
My W114 has been garaged for a year now and over the weekend I had to move it. Connected up a brand new battery and turned the key. The car turns over well enough but just won't spark. I pumped the accelerator a fair bit and couldn't detect a single hint of a petrol smell. The car has a third of a tank of fuel, so would you say the fuel pump has packed up? If so where is it and where can I get a new one?
Oh my other question is this: the car is perfect in virtually every way aside from needing a respray as the Merc red has simply turned to a light pinky grey. The car has done 50,000 miles and has only had one owner (my wifes great granny). Once its back up and running how much is a car like this worth - would it pay for us to have it resprayed and then sell it or are they worth so little it wouldn't make any financial sense to paint it?
Many thanks
Ben
stever
This is a trick for a w123, but I bet it would work...
Put your autobox into "D" and then try to start the car. It won't due to the safety inhibitor, but the fuel pump should run when you have the key turned to position three. If you can't hear a faint whirring noise from near the back of the car, your problem is the fuel pump. Try checking for power supply with a multimeter, and check the fuel pump relay - this can be by-passed by bridging the connectors.
As for the car colour - have you tried paint renovator?
As Stever could be the fuel pump stuck, itds under the off rear, just behind the wheel, Have a listen when someone turns the key.
Red Paint oxidises and the chances are with T cut it will come up perfectly
74merc
Northern Ireland
C280 Sport Estate
If you do a find on 'D-jet' on the internet you will find some good trouble-shooting guides on the fuel injection. I had a similiar problem with my 250CE, the engine turned ok but it didn't start. Plenty of spark but no power to the injectors - it seemed like it was a problem with the injectors but it was due to the fact that it had run out of petrol!
MyOldLady
Hello,
Many thanks
Ben
good morning
the fuel pump is at the back, under the car, jst behind the back axel, the fuel filter is also there, i would change the filter 1st then change the pump. to check if it is working, jst check when u turn the contact on the fuel pump should make a noise. if it does then its not the pump.
MyOldLady
ps
if u get it started and running, u wont sell it lol, i had the same thing 4 yrs ago i got given a 1972 250ce injection with 52k on the clock full service history, my plan was fix it and sell it. once i started driving it when i go out in town in the wkend, its a cracking car and i dont think i could ever sell it my old lady is the best car
MyOldLady
good morning
i have a 72 250 ce, and my fuel problem is, once my car starts ... it runs fine but it cuts out intermittenly.. i dont no why. sometime when i am driving alone it jurks and curts out, like its out of fuel. and the take is full, i changed the filters, and old plugs but still the same problem, i am thinking its the injection sytem. but not sure. its very hard to find a good mechanic in london. that knows about these cars
Dominic1976
Berkhamsted
W114 Coupe
Hi Ben
Do you still own the Merc. I am looking to buy one and live not too far from you in Berkhamsted. Thanks
Dom
obduro
Kent
2020 G63, 2017 AMG GTR
Holy thread revival, batman!
maz kamal
west london
mercedes w108,120,123,114 ,111
not starting w114,w124, any J tronic or D
When you are about to start the car and turn the key if you listen carefully , you can hear a hiss, if no hiss then fuel pump being the problem , check relay , fuse first and a multimeter for juce at the pump would be a good idea, if every thing fails then its the fuel pump
