W114 Coupe 1974 M110 Engine
Deanmyster
Newbury
280ce Coupe 1973
Thought I would ask the other owners for some help before I start spending more cash.
Symptom.
When accelerating the fuel cuts out completely when asked to deliver more fuel i.e. overtaking, going up a hill or flooring it. On a straight I can reach 60mph but only gradually. Their is no missfirering or acrid smoke.
I have replaced.
Fuel Pump
Fuel Filter
Kick down switch
Fuel pump relay.
ECU (opens and closes the injectors)
Mass air flow meter
The fuel pipes are all new and their is pressure evident on the other side of the regulator coming from the injectors.
I have ordered a new pressure regulator which I'm hoping will resolve the matter however I am now running out of suggestions on how to fix it.
D
Deanmyster
Newbury
280ce Coupe 1973
  • #2
W114 Coupe
I'm getting to the stage now where I might just sell her.
I've just splashed big cash on another fuel pump on my mechanics advice to no avail and changed the pressure regulator.
Has anyone got the slightest idea why my car will not accelerate to above 60mph.
I thank you in advance.
D
D
Deanmyster
Newbury
280ce Coupe 1973
Thnx for the advice, will get the girl tested out.
stever
Yes, find a Bosch specialist - you'll end up replacing half the engine otherwise.
D
Deanmyster
Newbury
280ce Coupe 1973
Fuel problems sorted to a fashion.
After speaking to Bosch the the part numbers for the fuel pumps turned out to be wrong there for a W123 series, SLIGHTLY CONFUSING as the engine in both is the M110. The pumps supplied were apprently to powerfull, operating at about 6 bar.
The 114 series injection models operate on out 2.5 - 3 bar presssure. Just about to fit the smaller pump, lets see how long this one lasts for!
I appreciate the help. Thanks
