W123 M102 engine - heavy breather
Peter C1974
Buckinghamshire
1985 W123 230E & 1991 W124 200E & 1999 W210 E240
Further to this post: http://forums.mercedesclub.org.uk/showthread.php?t=86218&highlight=w123+engine
The mileage has gone up by 20k since the above post and the engine is still running fine but I suspect it is breathing heavily.
Symptoms:
1. Oily smell from the exhaust.
2. Oil loss. Approx a litre per thousand miles.
3. Slight deposits of oil around the filler cap.
Positives:
1. Engine runs and pulls well.
2. Apart from a puff of blue smoke in the morning, there is no evidence of blue smoke (burning oil) during normal driving.
3. No oil leaks.
Apart from the breather pipe arrangement that I have cleaned and modified (see post above), does the M102 engine have any other crankcase ventilation pipes or valves?
Peter C
DIYMAN
Nr. Harrogate
E270cdi/53 plate/2.7l 5cyl.
The blue smoke on start up can be indication of worn valve stem oil seals. When I had the same engine I did a decoke and fitted new valve seals, after that I never had to top the oil up between changes.
star
Reading
Smart + others :)
Second this, these engines and 103 were very prone to the seals hardening, can be done in situ with the right tools.
Peter C1974
Peter C1974
Buckinghamshire
Thanks guys, I'll look into it.
Alex Crow
Super Suffolk
As above re. valve seals, used to change the, all the time on the 102/103, and not too bad a job if care taken and in-situ valve spring compressor available.
Never forget to make sure each cylinder is at TDC when removing collets though!
star
Reading
Smart + others :)
We do ours at Bdc, with compressed air holding the valve up and piston down. Either way is good.
Alex Crow
Super Suffolk
Actually, your way is better, but you better hope the collets are not too tight!
