W123 oil pressure issue
ShivaYash
Berlin
S124 1994 E200 (M111 engine), S123 1983 230TE (M102)
Dear all,
I have a 1983 230TE here in Berlin, Germany. It has around 295,000km (183,000 miles).
Oil pressure has previously been good, 3 bar at cold start, dropping to around 2 bar when warm.
Now I have this issue, at cold start, the pressure is around 2 bar... the needle is slow to get to 3 on acceleration. But once the engine is warm, I have full 3 bar pressure with the slightest touch of the accelerator.
Surely I should have full pressure (3 bar) at cold?
Something is not right. I'm running 10w40 MB 229.1 and either Hengst, Mann or Mahle oil filters.
I think there is crud stuck at the bottom of the oil pan. The last oil change had black spots in the filter lining.
I've done a few flushes... but I think the time has come to remove the oil pan and clean it properly...
Any tips or advice are most welcome.
ShivaYash
Berlin
  • #2
ShivaYash
Berlin
No judgements about the parking pole please ;-)
ajlsl600
france
Drop sump, look at screen, first run motor on sepperate oil press guage see if same results
rayhennig
1991 300CE-24 Sportline
Dear all,
I should try replacing the oil pressure sensor. Mine was reading 3 bar all the time indicating either open circuit wiring or faulty sensor. It was faulty sensor.
RayH
Yes the sensor fail, and they often fail in a way that just offsets their readings. Swap it out first or test the actual oil pressure with a gauge
Laubscher Calitz
Registered
W202 C220 1995 M111
I know this is an old post, but the W123 did not have a pressure sensor, it was a pipe directly to the cluster. Have you perhaps fitted the oil filter (Cartridge) upside down? This will definitely produce this symptom.
He is right, its a pipe, that switch is for the light only
