W123 rear window glass replacement?
Wolfenion
Malta
Mercedes W123
Hello everyone.
After an unfortunate incident I had last night, locking my car keys inside my w123 with the engine started, after going through the little choices I had I ended up grabbing a hammer and busted the rear passenger window open in order to open the door.. the pain.
I've already taken apart the interior of the door (removed all the glass and old window mount), and am in the process of looking for a second hand window.
My question is, how am I suppose to get the new window installed? I've removed the bottom window seal from the door frame (just took it off with no tools needed), and that seem to have left enough room for the glass mount to fit down through, but what about the sides? do I have to remove one (or both) side seals? If not that it seems like there's a lot of jamming to do in order to squeeze the glass onto the side rails (or seals or whatever they're called, not a technical person) so it can slide up and down like it should.
Thanks in advance for any help and suggestions given.
Little info on this, normally you remove the horizontal seal on the top of the door panel.
I I have anything on this I will post back
You would normally undo 14 and 29
m.mycat
NW_Merc
Banned
Oop Norf
Mercedes W202
Send a PM to Jay Manek, he has owned both the saloon and coupe versions and would be able to advise you more thoroughly.
W
Wolfenion
Malta
Mercedes W123
Ok, thank you very much people :)
