d215yq
- Mar 28, 2008
- Age
- 41
- Location
- Valencia, Spain
- 1987 W124 300D 280k miles
Hi all,
Just bought my first Mercedes - a w124 1996 e220 coupe auto (125k miles) and as my previous car was very different (a 1.4 Rover) I have a few (probably stupid) questions regarding the car.
1) I've not had an auto before but at low speeds in 4th gear the torque converter seems quite "loose" and engine revs increase from 1200 to 1600 without barely any change in speed of the car. Also on the motorway I still can't get more than 33mpg - Is this likely to mean the gearbox fluid needs changing or something more serious? (it was last changed 4 years ago at 100k miles).
2) once warm the temperature gauge fluctuates between 80 and 90 degrees depending on speed. The radiator looks OK but on previous cars the temperature gauge has always remained constant so is this normal?
(Also when the temperature gauge rises to 90 and the car is stopped the oil pressure gauge can dip to 2 instead of 3).
3) brake pedal sometimes feels spongy and if it is pumped quickly it becomes firmer. The car always stops very quickly and passed the MOT and the hydraulic system was checked - could this be solved by a brake fluid change or is somethign else likely to be wrong
4) the front windows sometimes judder a bit as they go up and down. As the coupe is pillarless which bits should i silicon grease to ease their operation?
If you have any DIY suggestions as to what to do regarding any of these I'd be grateful. I've just had it serviced and MOT'd and none of this was picked up so please tell me if I am just worrying about nothing!
Thanks,
Ben
Thanks,
Ben
